The rear version of that tire is too wide for the Qt50 so that’s your only option. You can use it on the rear no problem. I don’t see any difference in the tread between front and rear and on a stock qt you will going less than 1/3 of that tire’s speed rating. (edited)
Re: Can I use a front tire (NR77U) in the rear on qt50?
Subject | Written By | Posted |
Can I use a front tire (NR77U) in the rear on qt50?Topic by: Keno Rojas | Keno Rojas | 08/24/20 10:47PM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: Dirty30 Dillon | Dirty30 Dillon | 08/24/20 10:54PM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: Keno Rojas | Keno Rojas | 08/24/20 11:21PM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: Jack Rutherford | Jack Rutherford | 08/25/20 12:33AM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: Keno Rojas | Keno Rojas | 08/25/20 12:42AM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: Jack Rutherford | Jack Rutherford | 08/25/20 12:47AM |
Re: Can I use a front tire (NR77U) in the rear on qt50?Re: river 2strokes | river 2strokes | 08/25/20 05:20AM |
