I have a stock Honda pa50ii and my headlight broke. I was wondering if I could put a 12v light on without any issues? Just curious because they don’t make many 6v ones. Thanks
Will a 12v light work on a stock Honda pa50ii
Re: Will a 12v light work on a stock Honda pa50ii
You just need a good seal beam?
Short answer is no. Unless you convert the system to 12v (edited)
Yeah dude 12v bulbs on a 6v system work fine. They're rated for 12 volts but the 6 volts you're putting out will still light it up.
It won't be very bright.
12v bulb will probably work, but not as bright.
That said when I was wiring up my e50 maxi, I was just throwing whatever bulb fitted to make sure it was wired up right couldn't get the lights to work properly. Turns out having a 12v in the front and 6v in the rear (or vice versa) was throwing the resistance off or something.
Worked fine as long as I had matching voltage bulbs both end.
Something I've never heard mention, but might stop some head scratching.
You could make and install a voltage doubler .
Just get the treats replacement bulb, then you can replace filaments with the right one and not replace the whole assembly every time.
