LED headlamp conversion pictorial- bridge rectifier made easy.
Double Trouble Dan /
Here is an inexpensive way to make an LED conversion on almost any moped , scooter or motorcycle. Any decent H7 LED lamp can be used although depending on your AC voltage , a 6 volt lamp may be brighter. The 50A 1000v diode bridge rectifiers can be had almost anywhere for $2 . The diagrams show the AC input and the DC output to the light . This means less or no pulsing with voltage changes and the lamps will not blow out with voltage surges. You can also put a capacitor on the DC side with a diode across the terminals too to prevent voltage spikes , but I have not found it necessary for most applications.
This can also be done for the tail light or even both lights if you find a place to mount the rectifier near the stator. AC in - DC out .Just remember the the terminal turned differently is the DC positive and the pair of terminals are across (kitty corner) from each other.
I just finished this conversion on a broken sealed beam lamp . The lens was broken and I used an old headlight to cut the new lens and fit it in place. That is for another thread.
  LED headlamp conversion pictorial- bridge rectifier made easy.Topic by: Double Trouble Dan Double Trouble Dan 08/16/20 10:57AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Papa _ Papa _ 08/16/20 11:25AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/16/20 12:21PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/16/20 03:05PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/16/20 05:16PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Ryan Graeme Ryan Graeme 08/16/20 03:33PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Nick MBC Nick MBC 08/16/20 03:47PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Dave Thacker Dave Thacker 08/16/20 03:50PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/16/20 04:39PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Mark Younggren Mark Younggren 08/16/20 04:42PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/16/20 05:36PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Jax Rhapsody Jax Rhapsody 08/17/20 01:49AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/17/20 08:32PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Marc Friedman Marc Friedman 08/18/20 12:40AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/18/20 09:37AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/18/20 06:40AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Double Trouble Dan Double Trouble Dan 08/18/20 09:11PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/18/20 10:43PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Marc Friedman Marc Friedman 08/18/20 11:30PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: P D P D 08/19/20 08:52AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Per Kristian Sørpebøl Per Kristian Sørpebøl 08/19/20 11:04AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Marc Friedman Marc Friedman 08/19/20 11:26AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: P D P D 08/19/20 11:33AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/19/20 09:42PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Ron Kujawa Ron Kujawa 12/08/20 09:04AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Marc Friedman Marc Friedman 12/08/20 09:27AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Ron Kujawa Ron Kujawa 12/08/20 09:30AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Marc Friedman Marc Friedman 12/08/20 10:04AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Dirty30 Dillon Dirty30 Dillon 12/18/20 10:32PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Ron Kujawa Ron Kujawa 12/18/20 10:04PM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/19/20 02:00AM
  Re: LED headlamp conversion pictorial- bridge rectifier made easy.Re: Ron Kujawa Ron Kujawa 12/19/20 09:30AM
