> Mike Boyd Wrote:
> Weld a brake plate tab on the other side of the swing arm so you can
> flip the wheel around and run the sprocket on the correct side, if you
> can get the chain alignment right that might work
Exactly. If you don’t have access to a welder you can use a bolt for the brake tab. I did it before using a TOMos wheel on a one.
