I know this isn’t a moped but
How do I put the wheel above the brake shoes?
Re: I know this isn’t a moped but
Can't really tell.much from your pic but looks like you might be missing the brake drum
How do I adjust this?
Honda?
Izh Jupiter 3
It's a one-way axle, you can't adjust it on that side except with spacers, but if it's never been messed with (except for the mutilation it suffered) that shouldn't be necessary.
If the brake is properly seated i guess just tightening the axle nut should do the trick? (The bashed up round side on the other side of the axle is there to stick something through it to stop it from turning)
This one?
Your chain tensioner isn't put on right, so my guess is your wheel isn't put in straight. Fix that first then the brake will probably pop right on.
(Explaining these things in English isn't my strong suit)
Glad you knew from the pics what he has Bas,it had me totally confused..i thought a one point it was model t ford..
Pushrod Fifty /
Can you pic the whole bike please... Curious to see it.
Not in the best condition but it was cheap
damn that thing is pretty cool.
I'd be all over that . ;)
I have to ask : year , make and model , please .
Looks rubbish rn but it’ll get better
Pushrod Fifty /
Neat bike.
no clue why it sent twice but its a ural jupiter 3k from the 50s got the vin number bit idk how to decode it
Needed a battery but when I took the cover off there is only one wire and on wiring diagrams it has one wire to the electrics and one grounded to the bike????
Re taking bcuz of shitty image
If you confirm that the one wire is positive, then you just need to make one that grounds to the frame.
That some Russian bike? Take that to Garage54, let them trick that thing out with Lada parts and rebar wheels.
What do you call the thing that goes in this I know it pushes the float bowl down to let more fuel in but it’s missing it what is it called?
Dirty30 Dillon /
It's called a "tickler" or float bowl prime.
