How do I put the wheel above the brake shoes?
I know this isn’t a moped but
Re: I know this isn’t a moped but
Can't really tell.much from your pic but looks like you might be missing the brake drum
Honda?
Izh Jupiter 3
It's a one-way axle, you can't adjust it on that side except with spacers, but if it's never been messed with (except for the mutilation it suffered) that shouldn't be necessary.
If the brake is properly seated i guess just tightening the axle nut should do the trick? (The bashed up round side on the other side of the axle is there to stick something through it to stop it from turning)
Your chain tensioner isn't put on right, so my guess is your wheel isn't put in straight. Fix that first then the brake will probably pop right on.
(Explaining these things in English isn't my strong suit)
Glad you knew from the pics what he has Bas,it had me totally confused..i thought a one point it was model t ford..
Can you pic the whole bike please... Curious to see it.
damn that thing is pretty cool.
I'd be all over that . ;)
I have to ask : year , make and model , please .
Neat bike.
no clue why it sent twice but its a ural jupiter 3k from the 50s got the vin number bit idk how to decode it
If you confirm that the one wire is positive, then you just need to make one that grounds to the frame.
That some Russian bike? Take that to Garage54, let them trick that thing out with Lada parts and rebar wheels.
It's called a "tickler" or float bowl prime.
