Tomos A55 peak voltage level?
Adam Rodriguez /
Quick question, does anyone know what the peak voltage at max RPM on the lighting circuits for an A55 Tomos is? I'm interested because I'm looking to design a little box that can take in rectified and buffered AC and output DC to charge a lithium-ion battery and run lights. The basic idea is depicted below; use the ignition coil to drive a switching converter to get me a regulated 12V with no wasted power for the moped lights; when the engine is off a small lithium battery should get you an hour or so of lights before running out of juice:
https://imgur.com/gallery/GuJNONT
To do this though I'd need to know the highest voltage an A55 can hit under load, so I can spec out the switching converter properly, and I was wondering if anyone on here knew.
