Ebr forks help
Could someone let me know what size but these are. I've tried a few and can't find the right size.
Thanks
Re: Ebr forks help
Sorry spell check screwed me. I meant to say bolts.
Re: Ebr forks help
Probably m5x1
Re: Ebr forks help
M6 x 1 doesn't match. I also tried imperial stuff
Re: Ebr forks help
Mine have threaded holes, m6x1. Did someone ram the wrong bolts in or are they from the factory like that?
Re: Ebr forks help
Factory.
Re: Ebr forks help
The forks come like this from treats
Re: Ebr forks help
Dirty30 Dillon /
It's definitely just M6x1.
Although they're starting to look pretty muckled from your attempts
Re: Ebr forks help
To add to the M6 vote I’ll say something to maybe fix your situation.
You can’t get a bolt back in that spot, but you can cut the stripped bolts off. You’ll have to cut new M6 all thread to the perfect length and use something to temporarily support a nut inside that fork leg while you screw the threaded rod in from the outside. Then proceed to use as normal.
Way more tedious. So long as you aren’t taking that stabilizer-minifender off very often, it shouldn’t be a pain more than once.
Re: Ebr forks help
Thanks guy's it all worked out. I thought they were black bolts. The paint on the threads was really robust
