Tomos Targa A35
I'm having an issue with a small amount of oil blowing out of the muffler. I had a small gas leak that I fixed and it hadn't been started in well over a year but it fired right up. Is it blowing oil because it hadn't been started in a long while?
Re: Tomos Targa A35
How much oil are we talking? Is it like a spray of oil or dripping? Oil injection for the a35 is, IIRC, pretty generous so that might be why you're seeing a lot.
Re: Tomos Targa A35
Paul Brophy /
Like a spray.
Re: Tomos Targa A35
Sounds right if you had a gas leak. If gas was leaking into your cylinder, it would end up falling out to the pipe. There could be a pool of old gas that is still in your pipe that will not end up burning but will blow out your back side.
Just take it on a good run. If it is still spitting gas, then maybe your reeds are not closing properly and excess gas is getting in and not being burned in the cyl, again falling thru the pipe and blowing out.
Re: Tomos Targa A35
Paul Brophy /
Running great now after a nice 40 minute ride. Thanks
