i have a 1980 tomos with the encarwi carb that leaks fuel nonstop unless you shut off the gas. Will the delorto 14.12 with a new intake work and if so what throttle cable do i need? (edited)
You could just fix that leak, have you cleaned the carb yet?
Cleaned the carb but no luck getting needle to seat. My boy broke the throttle cable yesterday so figured it was a good time to switch it over.
