Re: Going tubeless on puch wheels without tubeless tires
🇮🇹💦 Of the Loin /
i had a tube popping problem the other day that ended up being that two spokes were too loose and causing a ridge to cut the tube even through the tube-guard strip or whatever its called
It would only happen after some time had passed, but luckily the marks were easy to understand (only damage was on the rim side, never on the outside)
so yeah theres a lot of stuff that fucks tubes up, but they mostly work good
