Peugeot Fox - Remove ignition lock?
Per Kristian Sørpebøl /
I find it very hard to remove the ignition lock on this one, it has two set screws that breaks off once it's tight. I drilled both of them and it's still very much stuck on there.
Re: Peugeot Fox - Remove ignition lock?
EH 📣FCC of the QCB /
Pic?
I managed to get it out, I just needed to drill out all of the bolts that holds it. They are made to snap when you tighten them which makes it harder to remove (or steal it)
