Stuck Flywheel
Noah Bachek /
For some reason my flywheel refuses to come out. I tried using a puller from Harbor Freight and it has worked many times in the past. But this time around It was so tight that it caused minor damage to the threads at the end of the crank it's mounted on. The keyway fell out a while ago so it's just fitted to the taper of the crank. With the nut in the center being decently tight. I've practically completely rebuilt this thing and the last thing I need to do is remove the flywheel! Any tips on how to do it would be great. (I've looked at other posts and they weren't quite what I was looking for)
