Re: How to Solder Throttle and Brake Cables
baird co /
Also, when I first did this, to test the strength, i used a vice, opened enough so the soldered end sat on top, with the cable hanging down (so nothing was squished in the vice,) then wrapped the loose cable around a piece of pipe, and used all my weight on the pipe to try to yank the soldered end off. Didn't budge it. Never had one come off.
