Taillight wiring question
First I apologize for the bad sketch. Now the sketch shows how my wires were hooked up as I took the light off. Now, the Grande wiring sketch shows , looking down, blue left , green center, right black. The base shows GST, ( photo) I’m assuming G is ground. My thinking is to hook them up as I took them off. The wire harness is original, no sketchy wire work. Any thoughts. BT W. This is another basket case , and it was in pieces , so engine wasn’t in a box .
Re: Taillight wiring question
your sketch is upside down, literally
SGT is Stop Ground Taillight
Look at the wiring diagram and figure out which wire goes to ground, which wire goes to your brake switches, and which wire is your taillight.
Yes like Nick said, LOOK at the schematic. Trace the wire colors back from the tailight to determine which color does what job. If the wire traces back to the brake handle switch then that color is probably the brake light wire and would go on the "S" for stop terminal.
My bad. Mario the sketch as you hold the taillight is good, I scribbled upside down. I shoulda looked at the schematic before I panicked. Got me good Cheetah! Now time to strip some wire.
T is for tail light
