All oldfashioned 4-stroke cycles need leaded gas. They'll appear to run fine on unleaded gas, but if you do the valveseats will wear much faster than they should. The lead is needed for lubricating the valveseats. More modern engines have a newer type of valveseats, these newer ones do not need the lead for lubrication.
