I just rebuilt a 16:16 sha carb and was unable to get the shim in the mount out. Any Ideas on how to get it out without destroying it? There is no gasket down there and would like to place the one that came with the gasket set.
Use a flat head pointing downward into the top slot, put your finger in the shim, twist the flathead, pull the shim out on your finger. Easier with 2 people or a vice to hold the carb when you do this.
Blind bearing puller baybeeeeeee
