Maxi Puch 1981 Front Fork Help
I am in the process of disassembling the front forks and removed all of the components, degreased and cleaned them. I was wondering what grease I should use to ensure optimum performance? If I am not mistaken, lithium grease would be suitable for all of the metal components but I am concerned it will degrade the rubber bushing at the top (part 21)? What grease would you all recommend? Thanks in advance.
Re: Maxi Puch 1981 Front Fork Help
Same answer as the other identical thread . You don't need to post the same question twice .
Use a good silicone grease . Same as used for faucet lube . Safe on rubber and the like .
Available at any decent hardware store . (edited)
