1962 Ducati Piuma 48 Restoration
Got this a coupla weeks ago locally.
Cleaned and rebuilt motor and carb. Got the missing side cover on eBay. Has spark, but can't start it without having pedals and clutch cables hooked up. Three speed, hand shifter.
Re: 1962 Ducati Piuma 48 Restoration
Had two to three old layers of non original paint, so off to the sandblaster
Back from the sandblaster:
Spent all day yesterday painting it:
Looks orange in the photo, but it's red. Very, very red. Because it's a ducati.
NOS rims and new spokes on cleaned and evaporusted hubs:
Got an NOS lafranconi frankfurter exhaust:
Domino shifter:
Here's some more before pics.
Here's some pretty motor pics.
Very cool. Have you found the tank for it yet? I hope so since you put so much work into it.
Ducati made 5500 of these from 61-68. The export ones have 4+ hp, and the non-export ones have like, 2.5 or something. This is the non-export, straight from italy.
They have a rear drum brake operated like a coaster brake by pedaling backwards, but I haven't figured out how that works yet.
Still need a tank and taillight. There's a tank in italy, but I don't wanna spend 250 bucks and wait a month or so for delivery, so I'm just putting everything else together for now.
I said it in the other thread. Absolutely beautiful.
This thread does not disappoint...love the before and after. Can't wait to see it finished.
Coolest VDO speedo drive ever:
Looks really similar to the aermacchi Harley m-50 component wise, I wonder if some of that stuff would swap, those seem to pop up pretty often, at least in the Milwaukee area
Yep, neighbor has one of those harleys, wonder if the tank is the same.
Looked into that. Some parts are close, but not close enough.
The ducati motor is similar to an early Morini 3M. But the Ducati cylinder has the intake cast into it, and the push me pull me shifting is totally different, as well as the rear brake.
Gotta hook up cables and a chain to figure it all out.
I mentioned it earlier, pedal backwards, some how it pulls the cable for the rear drum. Weird.
Here's the mind-boggling instructions
Welp, I've pretty much done all I can for now. Found a tank, taillight and headlight lens in Italy, but haven't bought them yet. It's more than I want to spend, and it usually takes at least a month to get stuff shipped here.
I could rig a tank and try to fire it up, but I have a potentially major problem.
The pedals don't engage. They just spin. So I'm gonna have to crack open the motor and figure out what's wrong. Hopefully it's something simple, like a woodruff key. If it's missing a gear or something else is broken, I'm pretty much screwed, because those parts don't exist.
But it's got spark and compression, so I could always push start it.
Anyway, here's where I'm at:
-picture would be here but it won't work.
Upload worked finally.
Pushrod Fifty /
Thats awesome and excellent resto work. The tank from a Wards 250ss moped would be close.
Christian Kyrmse /
That’s super sick dude. Awesome job on the restoration.
I always see that old ford truck in the background. Is that yours also?
Pushrod Fifty /
The autopart store 4 inch round trailer tailights will pass as an Italian one, the stud mounts are the same and you can paint the plastic housing and stick an 1154 in it.
It's my buddy/landlord's. Doesn't get driven much.
Taillight cover looks like this:
Top one is a light, bottom is a reflector, about 2" diameter, on an angled mount to fit the curve of the fram
I can make one of I have to.
Awesome build.
Is this the tank you’re seeing? I can buy something here and ship it via USPS for less than what you might pay.
I’m not trying to start an illegal export business here. But, I would help out with this beautiful project.
Pushrod Fifty /
Thats a pretty unique tailight. I like how the airbox tucks right into the frame. Is tne carb a Dellorto ME16?
Carb is a dellorto T4-12D1. Basically a 14-12.
Pretty complex for a little guy. Had to soak the whole thing in evaporust to get everything loosened up.
Thanks Papa! I sent you a PM.
Pushrod Fifty /
The ultimate shifty fifty.
Cant wait to see it with the tank painted and on it. That is way beyond sweet.
Found out why the pedals don't work. Wonder how hard this stupid thing is gonna be to find
Pushrod Fifty /
Maybe you can find the missing piece and weld it.
