Just installed big bore kit now staclutch is stuck won't start
Francisco Rodriguez /
Just installed a big bore kit now my starter clutch is stuck won't engage please help
Re: Just installed big bore kit now staclutch is stuck won't start
More info would help. What kind of engine?
Paul Funyun /
Jiggle the key and try again.
Overpriced Parts /
Did you prep the kit by chamfering all the ports So ring don’t get catch or get stuck?
Did you check and set gap ring to specs?
Did you base space cylinder and set squish .8-1.1 mm so piston don’t hit head?
Did you open up combustion chamber on head If too much compression like this:
Or did you just slap this high compression one that has way too much compression like this:
Did you put the piston in with the arrow facing down to exhaust port?
I’m willing to bet you didn’t check or do any of it
