Top speed for a puch Newport?
What is the approximate top speed for a stock 78 PUCH Newport? I’m getting about 25 on straight away. Stock carb and air box
Re: Top speed for a puch Newport?
Beach Club Nick /
25 is correct
^ and correctable! :)
Yeah, you might be able to do a couple things to your stock setup and get closer to 30, but you are feeling the top speed of that pony.
Probably Fred /
They made three versions 1hp 20hp, 1.5hp 25mph and 2hp 30mph
So 25 MPH is correct if it’s a 1.5 hp model but if it says 2hp on side plate you should be going 29-31mph stock speeds and with a bit of tuning nothin major close to 35mph,
Add a performance pipe, air filter, jetting changes and a re-gear of a bit bigger front sprocket or smaller rear sprocket you can get near 40 mph,
