Need advice. Solo Odyssey has mind of its own.
A few years ago I bought a 1978 Solo Odyssey 2 speed. It runs great for short distances but after a minute or so it accelerates on its own, then slows down, then accelerates again, etc- all this is happening but I'm not doing anything with the throttle. When I ride on hilly roads i noticed that it wants to go wide-open on downhills and kind of dies off on the uphills, sometimes completely just shuts off on larger hill climbs. I guess the best way to describe it would be like if it had cruise-control but its doing the opposite of what it should be doing to maintain a constant speed on hills. It wants to keep going when I try to stop. Its not the throttle cables, I had new put on recently hoping to fix this problem but its something else. Anything anyone can tell me would be greatly appreciated.
Re: Need advice. Solo Odyssey has mind of its own.
Overpriced Parts /
Fuel flow issue maybe
Read this :
https://www.mopedarmy.com/wiki/Fred%27s_Guide
The carb might be sensative to angles. Down hill might be leaning the mix out a bit and uphill might make it too rich. Maybe give it a good cleaning and see of that helps. It really sounds like a fuel flow issue.
Try raising the float a hair, after your sure the carbs getting enough fuel.
Tri-ped Dave O.D.B. /
also check that the pin hole in the gas cap isn't clogged
