Re: Air Leak
Dirty30 Dillon /
Spraying carb clean is the fast and loose way to find leaks. Obviously, any time you spray an aerosol anywhere near the carb there is a chance you are going to suck up some atomized solvent and cause fluctuations.
The only methodical and complete way to test for airleaks is a leakdown test. Which will expose pressure loss through covered seals or internal leakages between trans/crank, etc.
