> Art Vandelay Wrote:
> Thanks guys - I found I have an air leak where the carburetor bowl
> tightens onto the carb - which is weird because the rubber gasket is
> there and it's a brand new carb....... frustrating!
That is a weird place to get an air leak. I would suspect it is more at the intake where the carb goes on.. do you have an o-ring in the carb where it connects to the intake? There should be an o-ring and then the shim.
