> Art Vandelay Wrote:
> I’m running the one that came with the dellorto but I removed two of the
> three screens as somebody recommended. Would that make such a big
> difference? Was it a mistake?
A more restrictive air filter will richen the mix .
Just like a choke , only in varying degrees .
I'd try adding a screen and check . Then a second and check .
If that doesn't do , then try taping part of the filter , so it's even more restrictive .
Those steps will give you an idea of what's what . And , you may just decide to run one of those set ups .
Or , you could just spend more money on a bunch of jets .
