Jeff ,
Home is where your mom is .
Hone is what you do to a cylinder to come closer to perfection . ;)
Adam ,
Unless you're installing new rings , I'd run that cylinder as is . Cleaned , of course .
The more you take out , the less you'll have , compression wise .
Not to mention that the rings are worn to the cylinder as is .
If you remove the glaze , which is actually doing a hone job , the rings will wear more as they conform to the new cylinder surface .
Less compression .
