Re: Greetings from Winterpeg, Canada!!!
The Dude /
The broken piece is the fuel inlet. Most bing's use a banjo bolt style. That's a bing 12mm carb, you could buy one off ebay for cheap but be warned that they are crap and the idle adjustment screw is drilled incorrectly so it doesnt hit the slide so its useless. You could use all the parts off the copy to fix your though.
Some carbs have two cables for a push-pull style throttle.
  Greetings from Winterpeg, Canada!!!Topic by: Jon A. Jon A. 07/11/20 06:37PM
  Re: Greetings from Winterpeg, Canada!!!Re: P D P D 07/11/20 08:31PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/11/20 09:50PM
  Re: Greetings from Winterpeg, Canada!!!Re: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 07/12/20 07:11PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/12/20 07:54PM
  Re: Greetings from Winterpeg, Canada!!!Re: The Dude The Dude 07/11/20 09:58PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/11/20 10:26PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jeff Parr Jeff Parr 07/11/20 11:00PM
  Re: Greetings from Winterpeg, Canada!!!Re: 1950 Special Deluxe 1950 Special Deluxe 07/11/20 11:30PM
  Re: Greetings from Winterpeg, Canada!!!Re: Lucky Strikes Lucky Strikes 07/11/20 11:47PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/12/20 12:09AM
  Re: Greetings from Winterpeg, Canada!!!Re: P D P D 07/12/20 08:30AM
  Re: Greetings from Winterpeg, Canada!!!Re: Lucky Strikes Lucky Strikes 07/12/20 11:29AM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/11/20 11:51PM
  Re: Greetings from Winterpeg, Canada!!!Re: Steve Xoumph Steve Xoumph 07/11/20 11:53PM
  Re: Greetings from Winterpeg, Canada!!!Re: Bas Autowas Bas Autowas 07/12/20 08:44AM
  Re: Greetings from Winterpeg, Canada!!!Re: Pushrod Fifty Pushrod Fifty 07/12/20 07:43PM
  Re: Greetings from Winterpeg, Canada!!!Re: Jon A. Jon A. 07/12/20 09:11PM
  Re: Greetings from Winterpeg, Canada!!!Re: P D P D 07/13/20 08:05AM
  Re: Greetings from Winterpeg, Canada!!!Re: Pushrod Fifty Pushrod Fifty 07/13/20 07:35PM
