Engine stopping
Karlyne Von Krog /
Have been trying to adjust idle on moped, not sure I’m doing it right. Once I open it up to full speed it goes a bit and then conks out. I keep moving and it will restart but will conk out once I open it up.
Re: Engine stopping
Probably Fred /
Re: Engine stopping
FFuel restriction most likely. Float bowl not keeping up with demand.
Re: Engine stopping
What kind of moped?
Re: Engine stopping
> Mark Barney Wrote:
> What kind of moped?
Re: Engine stopping
Yes, the float needle may be sticking. If you remove the carb and unscrew the bottom float bowl. The whole thing just unscrews. Careful of the gas in there.
Once in you will see your float bobber. That is held on by a pin. Push that pin out and you will be able to remove the float. You will see in a little channel on the float the needle valve. Check that the rubber tip is not too misshapen. If it is then you will want to replace it. If it looks ok still, no bloating or smashed tip, then you can give the needle tube a nice clean and polish, which should help it from sticking. If it still persists then the needle may need to be replaced.
treatland will have all the goodies you need to rebuild the carb.
