How can I run an old moped without the ignition switch?
I have an fa50, but the process may be similar on other bikes.
I have no ignition switch, and want to test spark. Is there a way to bypass it? Thanks
Re: How can I run an old moped without the ignition switch?
Yes
Take it out, connect the wires and done.
But there's 6
There is info on it in the wiki you can look up...i have it copied down on paper but it is at my shop and i won't be back there until next week.
I found an old post.just now that says just unplug your switch from the harness and you will have spark...it also says make sure your emergency switch is working ... (edited)
What kind of info? I don't know enough about wiring to figure it out based on diagrams, I basically need somone to explain it to me like I'm 5 lol. Thanks
Unplug the connector that plugs in to the ignition switch...plastic plug with wires in it ...unplug it
Re: TENTANG INDOJAYA EPOXY
> Antonius Setiono Wrote:
REPORTED ... SPAM
