Re: JCP Swinger 2 -air leaks and then fuel starvation
Mike Pavlik /
Will definitely have to play with the needle again then, bump it up one notch probably. I’ll get a new float needle ordered along with some other treats, then change the needle clip and swap the float needle at the same time. After that hopefully I can leave the damn carb alone for more than a week. adding more pics of the carb.
Everything else inside looked pretty good (although again, what do I know). Already ordered carb gaskets and I’ll probably swap out that gasket on the top of the carb where the throttle cable and choke go in, it’s still in one piece but the layers of the material are separating. After the intake gasket I found out cutting them isn’t as easy as I thought.
Thanks again for the follow-ups!
  JCP Swinger 2 -air leaks and then fuel starvationTopic by: Mike Pavlik Mike Pavlik 07/09/20 04:08PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:14PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/09/20 04:40PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:43PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 04:50PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 07/09/20 04:57PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 05:04PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 10:51PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/10/20 02:11AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 02:22AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 08:52AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:15AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/13/20 12:16AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:18AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:26AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:37AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 12:56PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 02:24PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 02:54PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 03:10PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 03:48PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:38PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 04:44PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:59PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Stephen Keller Stephen Keller 07/10/20 07:56PM
