Re: JCP Swinger 2 -air leaks and then fuel starvation
Jay Rivett /
For the stock setup. I would put the needle clip in the middle position. You have it pretty rich with the clip in the lowest spot which can definitely make you bog on the low end.
I would definitely look at replacing that float needle. It might be good for a bit, but the rubber tip has softened and changed shape slightly which is what caused it to stick, but now it could possibly not seal and you end up with your carb over flowing everywhere.
  JCP Swinger 2 -air leaks and then fuel starvationTopic by: Mike Pavlik Mike Pavlik 07/09/20 04:08PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:14PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/09/20 04:40PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:43PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 04:50PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 07/09/20 04:57PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 05:04PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 10:51PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/10/20 02:11AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 02:22AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 08:52AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:15AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/13/20 12:16AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:18AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:26AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:37AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 12:56PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 02:24PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 02:54PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 03:10PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 03:48PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:38PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 04:44PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:59PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Stephen Keller Stephen Keller 07/10/20 07:56PM
