Re: JCP Swinger 2 -air leaks and then fuel starvation
Jay Rivett /
2 things to check.
1 if it is fuel it could be the float needle is sticking and not letting fuel to flow as easily as it should. But when the bike is off fuel still trickles down and eventually fills the bowl.
2 if it is electrical, it sounds like a bad condenser. They will run fine when cold but after a couple minutes they warm up and fail.
Check the float out first as it is easiest to get into. For the condenser you will need to purchase a flywheel puller tool to get to the stator plate with the condenser.
  JCP Swinger 2 -air leaks and then fuel starvationTopic by: Mike Pavlik Mike Pavlik 07/09/20 04:08PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:14PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/09/20 04:40PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:43PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 04:50PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 07/09/20 04:57PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 05:04PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 10:51PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/10/20 02:11AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 02:22AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 08:52AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:15AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/13/20 12:16AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:18AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:26AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:37AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 12:56PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 02:24PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 02:54PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 03:10PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 03:48PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:38PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 04:44PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:59PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Stephen Keller Stephen Keller 07/10/20 07:56PM
