JCP Swinger 2 -air leaks and then fuel starvation
Mike Pavlik /
Hi all, thanks in advance for any input, first bike, trying to get it running the right way. Searched around the forum and have some ideas on how to fix my problems but want to run it by people who aren’t as green as I am.
Got a Swinger 2, was running rough when I bought it. Had a bunch of funky repairs done that I’ve been sorting out.
Main thing was an air leak - 10 mins after riding, would not respond to more than 1/4 throttle, anything more and engine would bog down. Air leak. Sprayed carb cleaner, found leaks at both ends of the intake elbow. Cut a new gasket for the bottom, jammed an o-ring between the intake elbow and the carb. Cleaned exhaust pipe and baffle for good measure. Sprayed again, no leaks. Sweet!
Fired up, idled, rode for 2 mins and then died. Not Sweet! No air leaks, seems fuel starved not electrical but who am I to say?I checked the fuel line and gas is flowing. Thinking it simply isn’t tuned right.
My laundry list of things to do is: take apart the carb(note: I’ve done this once before already to replace throttle cable and clean it), increase the fuel ratio on the little clip, check for clogs or any damaged parts, get the jet size if possible (I think it’s a bing 12 clone so jets may be blank) make sure float is sitting correctly, reassemble.
After that I don’t know which way to go, maybe check spark plug and points, or play with the idle screw more? Or should I be looking at the petcock and fuel flow more? It really feels fuel starved now that more air is coming through. Added some small pics of the bike in all its glory and the carb in all its misery.
  JCP Swinger 2 -air leaks and then fuel starvationTopic by: Mike Pavlik Mike Pavlik 07/09/20 04:08PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:14PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/09/20 04:40PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/09/20 04:43PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 04:50PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 07/09/20 04:57PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 05:04PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/09/20 10:51PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Boyd Mike Boyd 07/10/20 02:11AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 02:22AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 08:52AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:15AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/13/20 12:16AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:18AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 10:26AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 10:37AM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 12:56PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 02:24PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Jay Rivett Jay Rivett 07/10/20 02:54PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 03:10PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 03:48PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:38PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Mike Pavlik Mike Pavlik 07/10/20 04:44PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: P D P D 07/10/20 04:59PM
  Re: JCP Swinger 2 -air leaks and then fuel starvationRe: Stephen Keller Stephen Keller 07/10/20 07:56PM
