Re: 16mm Malossi carb for Puch
Brandon Eliason /
another thing to consider, two speed bikes require a taller intake so the carburator clears the crankcase. it looks like the intake sits pretty low on that kit. you might end up needing a spacer to make the intake taller.
  16mm Malossi carb for PuchTopic by: brian p brian p 07/05/02 03:34PM
  Re: 16mm Malossi carb for PuchRe: CASEY CASEY 07/05/02 04:16PM
  Re: 16mm Malossi carb for PuchRe: Brandon Eliason Brandon Eliason 07/05/02 04:40PM
  Re: 16mm Malossi carb for PuchRe: CASEY CASEY 07/05/02 05:23PM
  Bing 15mmRe: Brian P. Brian P. 07/05/02 11:50PM
