> Satan 666 Wrote:
> > Garrett The Kid Wrote:
> > That’s just a welding tip cleaner, sold at most stores that stock
> > welders.
> Yep. They sell little micro drills that you can drill and use as the
> dude said above. Sucks buying a bunch of jets and never using them. The
> welding tip reamer wont do a thing for your jets. I have never even used
> one to clean my welding tips.
It will remove slight amounts of the jet to open it up, takes a bit to do but can work if you need just slightly larger than what’s there. I’m talking .5 to 1 size at max, did it on a tx50 that disliked the stock jet
