Garelli NOI
Hello,
I need an Output shaft for my 81 NOI 2 speed.. I was wondeirng if this part would fit my engine?
-->OutPut shaft
I am not a Garelli expert and I know almost nothing about mopeds. Im still very new to this.
Re: Garelli NOI
That part is not worth what they're asking. I might have another whole NOI motor, let me see and I'll get back to you.
Re: Garelli NOI
Also I do not think that is the one you are needing. I do not know why it would have threads at the end of it.
Re: Garelli NOI
I believe the threads at the end are for sprockets and washers to keep the 11 Point sprocket on. This is what would drive my chain to move.. Diagram
See 18-20
Re: Garelli NOI
Ah yes, I forgot that garelli has a nut holding the sprocket in place. Many other bikes use a circlip to lock it in place.
I would get yours out if the bike first and take some measurements. Cheetahchrome can attest to the issues with these garelli engine parts.
Re: Garelli NOI
Nick see if the crank is good in that motor Ha Ha.
Not kidding
Re: Garelli NOI
Yes I agree with nick. You need to pull your broken shaft out to know for sure.
Frankly I think you are in over your head. Just pulling apart my 1 speed took special tools that I had to modify.
Better look for an experienced motor cracker.
Re: Garelli NOI
BYW this shaft that I wrongly suggested earlier if for the vertical VIP motor and is NOT in fact what you need.
Re: Garelli NOI
Could this be what Ian needs?
Re: Garelli NOI
Nope I dont think thats it either. I think it is this one in this schematic of Garelli H2
If you look close the shaft looks almost the same as the Garelli H1 except that the H2 shaft has the keyway (#17) slot to hold the one way roller hub.
Here is the Garelli H1 schematic. See, no keyway.
Yes this guy needs to pull the part then start asking.
Re: Garelli NOI
All transmission parts are different between the 2 speed and one speed noi.
Re: Garelli NOI
Dave Thacker /
You the one with the Garelli over north of Indianapolis? Saw one for sale over there needing this shaft.
Re: Garelli NOI
Nope. I butcher them or repair them.
