> Jacob Ohse Wrote:
> I got to thinking about that today. If the decompression valve would
> affect that at all to where I wouldn't get compression when checking it
> like that. I plan to throw a bolt in there to see if I can plug it up
> and still get compression after. Was planning on filing and cleaning up
> the points tonight.
An easier way to check is to have someone pedal it and feel the exhaust, there should be some light air hitting your hand. I don't check for compression unless the bike absolutely won't start. I don't think it's worth fiddling with the decomp to check for compression. If it turns over you're good 9 times out of 10
