Party cdi
Sorry I searched for an answer but I can't find one. Red or Blue permatex threadlocker for reassembly?
Re: Party cdi
I just pre tightened all the screws with a proper fitting screwdriver and went with it
If you start putting threadlock on m5 screws going into aluminum you might hate life later when you need to get that weak Chinese screw out.
Re: Party cdi
> and went with it
No might about it .
No thread locker need .
Re: Party cdi
Maybe some locker, I noticed a weird rattling around about a week after I installed my CDI and found that one of them had backed out and was a couple rotations from destroying a coil.
Put one drop of blue thread locker and it holds it in place but let's go when you want it to.
Re: Party cdi
You only need to heat the screw up to remove it, you can use an electric heat gun or a soldering iron or fire if you can control it and not melt your stator
Loctite releases at 500f, but it gets "weaker" before that.
I would use blue, but red would work in a pinch.
Re: Party cdi
Thanks guy's your help and knowledge are greatly appreciated.
Re: Party cdi
When needed , auto touchup paint works great as thread locker .
Re: Party cdi
I would not use any on the bolts holding your stator plate. Just make sure they are nice and hand tight. The nut for the magneto you could use some locker on. I would wait until you get yourself 100% dialed in before permanently putting on your flywheel nut. I have seen in touched original bikes that had a red thread lock put on from factory. But you would be fine with blue and would be easier to remove as needed.
I do not typically use either, but have both on hand in case I feel the need.
