Re: Tap & die kits
Pushrod Fifty /
I buy M6 taps and other as needed taps at a hardware store. Look online for the correct drill bit size for a 75% thread which is what most are and buy as needed. The sets will be cheap unless they are a good name. I have an M6 die that I use to clean threads. Comes in handy. Hanson brand is pretty good. Use a tap wrench and oil, they break easily if forced from side to side from using pliers or other incorrect tools.
  Tap & die kitsTopic by: Les B. Les B. 06/27/20 09:08AM
  Re: Tap & die kitsRe: Eric Davenport Eric Davenport 06/27/20 09:13AM
  Re: Tap & die kitsRe: Les B. Les B. 06/27/20 10:38AM
  Re: Tap & die kitsRe: P D P D 06/27/20 12:02PM
  Re: Tap & die kitsRe: Les B. Les B. 06/27/20 01:32PM
  Re: Tap & die kitsRe: Papa _ Papa _ 06/27/20 09:17AM
  Re: Tap & die kitsRe: Rick Shaw Rick Shaw 06/27/20 09:19AM
  Re: Tap & die kitsRe: Papa _ Papa _ 06/27/20 12:02PM
  Re: Tap & die kitsRe: P D P D 06/27/20 12:05PM
  Re: Tap & die kitsRe: Pushrod Fifty Pushrod Fifty 06/27/20 02:37PM
  Re: Tap & die kitsRe: D L D L 06/27/20 04:02PM
  Re: Tap & die kitsRe: Probably Fred Probably Fred 06/27/20 05:16PM
  Re: Tap & die kitsRe: Pushrod Fifty Pushrod Fifty 06/27/20 05:24PM
  Re: Tap & die kitsRe: Les B. Les B. 06/27/20 05:55PM
  Re: Tap & die kitsRe: cheetahchrome . cheetahchrome . 06/27/20 06:40PM
  Re: Tap & die kitsRe: Dave Thacker Dave Thacker 06/27/20 10:52PM
  Re: Tap & die kitsRe: Les B. Les B. 06/28/20 07:25AM
  Re: Tap & die kitsRe: Pushrod Fifty Pushrod Fifty 06/28/20 09:24AM
  Re: Tap & die kitsRe: Dave Thacker Dave Thacker 06/28/20 01:46PM
  Re: Tap & die kitsRe: punkrock randy punkrock randy 06/28/20 09:33AM
  Re: Tap & die kitsRe: Pushrod Fifty Pushrod Fifty 06/28/20 09:46AM
  Re: Tap & die kitsRe: P D P D 06/28/20 10:38AM
  Re: Tap & die kitsRe: Probably Fred Probably Fred 06/28/20 11:31AM
  Re: Tap & die kitsRe: P D P D 06/28/20 11:57AM
  Re: Tap & die kitsRe: baird co baird co 06/28/20 02:02PM
  Re: Tap & die kitsRe: Les B. Les B. 06/28/20 11:23AM
