Re: EBR forks
Satan 666 /
> Marc Friedman Wrote:
> So about the ebr forks? Is there any similarity to the functionality and
> the design of these EBRs to say a typical motorcycle or a typical
> mountain bike fork on the mountain bike fork one side has an air chamber
> that you can pressurize and the other side has a oil sealed side that
> functions as a damper and there's oil holes that oil goes from one side
> and there's a positive and there's a negative side All this kind of
> stuff is on a say a fox factory shock or a rockshock. What's inside an
> EBR? How seriously are these things made.
If you get the hydro forks they are decent. If you get the cheapo you get what you pay for. They are shit quality with little to no dampening but a good replacement for worn out stock crap. You will need to buy a brace or you will be scared as you can grab the bars and twist and watch the wheel turn by itself. Hey they look cool!!
Also if you plan on running low bars with the cheapest ones plan on having almost no travel as all your weight will make them bottom out every bump. Its mopeds but get the hydros and get some heavy weight oil. (edited)
