Oh boy, why am I doing this? Oh yeah! Cause fun! I got this crusty lil quad sitting out in front of a house after some folks moved out and left behind a bunch of trash. Well you know how it goes, one persons shitty clone quad is another persons donor for an E50 swap. Classic. Anyway, here's a few pics of it before, stripped and ready for some hacking:
E50 quad build
Re: E50 quad build
It wasn't too far off from the original mounts to fit the E50, just a little narrowing and relocating of the bottom engine bracket. I guess it was kind of some work to get an angle grinder inside of this weird frame and cut out the old mount to narrow/remount it, but its solid now! Ok the last picture is a look at how dumb this thing is getting... I say Grave, you say...?
Re: E50 quad build
Digger!
Re: E50 quad build
dang, nice! I was thinking this was one of those honda puch 4 wheelers, there were some that were like that size mini 4 wheeler with an oddball version of the Hero e50's
but this was just the cubclone 50 originally?
Re: E50 quad build
Yeah man I was inspired by one I rode in a dirt lot, the "Wheelie." Super fun, but it didn't have good suspension at all and would easily flip doing donuts haha. But yeah this is just a clone of Honda horizontal engines, made by Roketa. A tad bigger than the Hero one, but still made for kids, it's gonna be a blast...
Re: E50 quad build
I has the weirdo e50 engine for the wheelie... 2 of them. One with the electric start motor still. I am over them. Let me know if you want something like that... one had a new hero 65cc kit. I have another 65cc kit that was poorly cast and an iffy piston. I also have a stock cyl and a couple heads... just sayin.....
Cool build. Way better suspension than the wheelie I had. Closer to the avanti quad for sure.
Re: E50 quad build
Nice you have a cosmo cub too
Re: E50 quad build
I passed on buying a e-start 65cc dual-variated vespa moped motor-powered quad like 7 years ago and it's my biggest moped regret ever.
Re: E50 quad build
Damn yeah those vespa motored quads are rad and elusive!
Re: E50 quad build
we have one of the puch motor quads in our shop, (which the shop itself we affectionately refer to as "the quad" - it's a 4 bay garage)
currently no spark, having trouble making replacement ignition work but maybe it's a directional issue.
Re: E50 quad build
This is excellent Moped content.
Re: E50 quad build
Made some progress, the original sprocket was a larger chain size so I found a Sachs rear that (kind of) works out. Just had to drill the four holes out a lil bit and now it bolts right up to the sprocket carrier! Chain alignment looks great, thumb throttle dialed, even got the key ignition wired up and two keys, coooool... It's basically ready to fire up and test at this point, tomorrow I'll make a pipe for it.
Re: E50 quad build
Holy shit, wonder if the dimensions are similar?
You could drop that body right on top
Re: E50 quad build
That body would totally fit on that quad! Of course with modification and mounting figured out. But I bet it would be real close off the bat.
Re: E50 quad build
Re: E50 quad build
My nephew has that Gravedigger. It's larger than the quad, for sure, but a body transplant could work
Re: E50 quad build
You’re gonna have to ask will c about what he did to make a hero cdi work on it. Like maybe he used the za50 box or flipped the coil or something like that to make it work with the inverted flywheel.
Re: E50 quad build
oh man, yeah mine didnt have spark and i used a treats cdi stator plate, flipped the pickup location and i think used a za50 cdi box. i basically just tried every combination of cdi box, ignition coil direction and pickup location until the timing was correct lol
Re: E50 quad build
Sounds like it would have been a lot easier to build a new flywheel . ;)
Re: E50 quad build
Can’t get a flywheel as the stator plate bolts onto the side cover and the magneto is on the crank facing out.
Re: E50 quad build
Pipe making time, used this old weird pipe from a Morini dirtbike, which was already modified. Took a sec to figure out angles but I'm happy with the results.
Long story short:
Ok this thing is sketchy, wow so fun... Went on a beverage run for first ride, brake caliper fell off and I met Mr. Bush on the way back, what a guy.
Re: E50 quad build
Haha tiny machines are fun. I loved my magnum x but sold it after I had way to much pbr and crashed it pretty hard.
Re: E50 quad build
Great work Sean! That thing is awesome
