> pat splat Wrote:
> > Dirty30 Dillon Wrote:
> > Can't really run it sideways, without plugging the wristpin holes in
> the
> > piston.
> would this matter? once the exhaust is out n transfers open the wristpin
> its all below the rings. i need a visual. Forgot about the cutouts in
> a piston as well.
> totally nuts to have a carb on the ground as well as the pipe on your
> leg.
Just a rough idea, but view the MK port map below
With a ~10mm hole, you would have a portion of the stroke where the intake would flow straight out the exhaust, causing a complete loss of pumping pressure.
Also, carb on the ground isn't crazy. The Laura M48 motor has an underslung carb, as does the Vespino motor.
In a lot of ways, it makes sense to have your carb away from upward-rising heat. Keeps the fuel and air colder, so it's more efficient.
