Vacuum leak?
What’s a good solution for loose connection between carb and intake inlet on Dellorto for Tomos
Re: Vacuum leak?
Dirty30 Dillon /
Replace the shim with a new one. If it still won't clamp down, than the clamp on the carb is probably stretched out.
Re: Vacuum leak?
Mosley Frank /
Think it’s running to lean .have 75 main jet In carb
Re: Vacuum leak?
Mosley Frank /
Thank u
