Re: Anyone rebuild the seatpost from square to round?
Papa _ /
Sandra,
I wouldn't weld it unless you have too. I think a more elegant (and reversible) solution would be to find the correct diameter of Round Tube to fit the new seat mounting clamp. I think it will fit inside the square hole on the frame. Then mark the holes that line up and drill for bolts to secure it. If it isn't a tight fit, get some flat steel to make shims. The bolts will probably be sufficient to hold you. If there is wiggle room, the bolts may eventually wear at the frame. So make the pipe a tight fit in the frame and the bolts just there to stop it from going up or down. Clamp the seat on the round pipe that sticks above and you're good to go.
  Anyone rebuild the seatpost from square to round?Topic by: Sandra Ström Sandra Ström 06/23/20 12:44AM
  Re: Anyone rebuild the seatpost from square to round?Re: Aaron Blair Aaron Blair 06/23/20 01:35AM
  Re: Anyone rebuild the seatpost from square to round?Re: Sandra Ström Sandra Ström 06/23/20 03:52AM
  Re: Anyone rebuild the seatpost from square to round?Re: Born to be WillD Born to be WillD 06/23/20 05:58AM
  Re: Anyone rebuild the seatpost from square to round?Re: Sandra Ström Sandra Ström 06/23/20 11:43PM
  Re: Anyone rebuild the seatpost from square to round?Re: pat splat pat splat 06/23/20 09:31AM
  Re: Anyone rebuild the seatpost from square to round?Re: Pops Peds Pops Peds 06/23/20 04:27PM
  Re: Anyone rebuild the seatpost from square to round?Re: Papa _ Papa _ 06/24/20 07:36AM
  Re: Anyone rebuild the seatpost from square to round?Re: Sandra Ström Sandra Ström 06/24/20 01:53PM
  Re: Anyone rebuild the seatpost from square to round?Re: Sandra Ström Sandra Ström 06/24/20 01:54PM
  Re: Anyone rebuild the seatpost from square to round?Re: baird co baird co 06/24/20 09:21PM
  Re: Anyone rebuild the seatpost from square to round?Re: Papa _ Papa _ 06/24/20 07:47AM
  Re: Anyone rebuild the seatpost from square to round?Re: Mike Scouty McScoutington Mike Scouty McScoutington 06/24/20 09:21AM
  Re: Anyone rebuild the seatpost from square to round?Re: Papa _ Papa _ 06/24/20 01:58PM
  Re: Anyone rebuild the seatpost from square to round?Re: Sandra Ström Sandra Ström 06/24/20 10:44PM
  Re: Anyone rebuild the seatpost from square to round?Re: Pops Peds Pops Peds 06/25/20 07:19AM
