Re: Petcock attachment
Born to be WillD /
oh, it's basically just a screw with a hole down the middle. I'm not suggesting you should use that exactly - just explaining a simple creative solution to macguyver some shit with some parts alotta moped folks have laying around, they come on your throttle and carb top and brake cables etc etc. and when you buy new cables, you usually get new ones so you got some of these rando pieces around that are effectively little metal tubes, and honestly all you need to get a fluid out of a metal container and into a fuel line is a little metal tube
so yea, in short, anything works. grab a hollow bolt, or a barrel adjuster, or a piece of metal tubing or a coupler nut, or a drilled out grease fitting or a proper hose bung --- anything roughly the right size to jam fuel line on and have it get outta the tank.
  Petcock attachmentTopic by: Paul Monaco Paul Monaco 06/22/20 06:34PM
  Re: Petcock attachmentRe: roy jongejan roy jongejan 06/22/20 06:36PM
  Re: Petcock attachmentRe: roy jongejan roy jongejan 06/22/20 06:39PM
  Re: Petcock attachmentRe: pat splat pat splat 06/22/20 06:56PM
  Re: Petcock attachmentRe: Paul Monaco Paul Monaco 06/22/20 09:34PM
  Re: Petcock attachmentRe: Jeff Parr Jeff Parr 06/22/20 09:47PM
  Re: Petcock attachmentRe: roy jongejan roy jongejan 06/22/20 10:00PM
  Re: Petcock attachmentRe: pat splat pat splat 06/22/20 11:54PM
  Re: Petcock attachmentRe: Paul Monaco Paul Monaco 06/23/20 05:12AM
  Re: Petcock attachmentRe: P D P D 06/23/20 10:47AM
  Re: Petcock attachmentRe: Paul Monaco Paul Monaco 06/23/20 07:25PM
  Re: Petcock attachmentRe: P D P D 06/23/20 08:33PM
  Re: Petcock attachmentRe: Dirty30 Dillon Dirty30 Dillon 06/26/20 10:40AM
  Re: Petcock attachmentRe: baird co baird co 06/23/20 12:41PM
  Re: Petcock attachmentRe: Trent Anderson Trent Anderson 06/23/20 11:36AM
  Re: Petcock attachmentRe: pat splat pat splat 06/23/20 11:49AM
  Re: Petcock attachmentRe: Jeff Parr Jeff Parr 06/23/20 01:13PM
  Re: Petcock attachmentRe: Les B. Les B. 06/25/20 06:52PM
  Re: Petcock attachmentRe: Born to be WillD Born to be WillD 06/25/20 11:30PM
  Re: Petcock attachmentRe: Paul Monaco Paul Monaco 06/26/20 05:27AM
  Re: Petcock attachmentRe: Born to be WillD Born to be WillD 06/26/20 06:02AM
  Re: Petcock attachmentRe: Stephen Keller Stephen Keller 06/25/20 07:05PM
  Re: Petcock attachmentRe: pat splat pat splat 06/25/20 09:25PM
  Re: Petcock attachmentRe: Jeff Parr Jeff Parr 06/26/20 10:37AM
  Re: Petcock attachmentRe: Jeff Parr Jeff Parr 06/26/20 11:47AM
