Gear oil fill plug cap broke off!!
My gear oil fill screw broke off as I was tightening it! It now leaks a lot of oil out of the fill plug when I ride it. Any ideas on getting the shaft out and what to replace it with?? Thanks See pics
Re: Gear oil fill plug cap broke off!!
you can drill em out or you can buy drill bits to remove them
Dirty30 Dillon /
They're plastic, you can typically just use a flathead to turn it out.
As for replacements, reach out to doscycles.com and see if they have some back stock
This forum is awesome! Thanks guys
Terbo Speghetti /
Use gum
roy jongejan /
if its plastic, heat up a flathead screwdriver and push it in, then turn it out after cooling down
Great idea! I’m going to try heating up a screwdriver. It is plastic and I ordered a new one on dos cycles. Should be here in a few days. I’ll skip the chewing gum idea.
