Hey guys,
Have had some trouble getting my puch running. I installed a new condenser (solder type) because my bike would die once it got warm as if there was no spark. Here is my setup:
Treats 70cc kit
Mikuni vm20 with 130 main and 2.17 idle
Leanest needle clip setting
Proma circuit
17x45
The bike will start and idle, but seems very rich/laggy when I give it throttle. Plug is black and sooty. It has terrible low end and will eventually die. Got it to stop backfiring out the carb by resetting my points gap. Timing is set to 17* btdc, I've checked for air leaks, tried a new plug, so I'm thinking it's something to do with ignition. Can't seem to get this thing ripping. Here is a photo of the stator wiring. I think there could be a bad ground somewhere but I have no clue how to check that. I just redid my wiring as I eliminated everything but headlight and tail light, so everything seems to be in the right position. (edited)
