22T rear sprocket on a v1?
I bought a NOS rear wheel from DOS for my Cimatti and it came with a 22 tooth rear sprocket. Can I run one that small with a 10 front? or should I swap back to the stock 44T
Re: 22T rear sprocket on a v1?
swap it back to 44t.
That's what I was figuring. What italian bikes came with a 22 rear?
kinda sounds like a tomos geared rim. im not sure about gearing on different minarelli motors. it could be correct for others. if it is a true oem cimatti rim 22t will never work on v1. that much i know.
It wasn't a cimatti rim necessarily, just a NOS rim for a v1/italian bikes
I'll swap it out, was just curious
I've gone as low as a 36 rear sprocket, but it won't climb hills worth a darn. If you live in a flat area, that thing would probably hit 60 mph but take forever to get there.
Definitely not flat haha. San Diego is hilly as hell. 10x44 will be good for that
That should get you 25. A 9 will get you 20 with better hill climbing. I understand the make an 8? 17 tops.
You can get away with a 10/34 or 11/34 with some hill climbing ability if it's kitted.
🇮🇹💦 Of the Loin /
That was probably a 2spd but yeah Tomos and Minarelli use z sprockets
Lowest I've run is 11x33 and the setup I have tops out right around 52-55 mph depending on winds
The Minarelli is geared about twice as high as an MO or Mo2 OR M1 engine. You gear it to a sprocket meant for Morinis(biggest rear sprocket on Morini I've seen is 34T), and you'll be walking the ped up long hills. Of course, front sprocket can change a lot.
Dirty30 Dillon /
I could very well be a NOS Cimatti wheel... you're just assuming that it's V1 powered.
> it's V1 powered.
I've never seen a Cimatti that was later than 1970s without a Minarelli . (edited)
Dirty30 Dillon /
> > it's V1 powered.
Then you need to up your research game.
🇮🇹💦 Of the Loin /
why are the greatest Italians always brothers?
legit question
> legit question
Sibling rivalry . ;)
Dirty, go to photos on this site. 70+ Cimattis…............…...all I see are Minarellis.
Dirty30 Dillon /
> are Minarellis.
Don, I can't stop you from googling Cimatti and looking at all the great moped they made that never came to the US.
Only you have that power.
They mostly used minarellis. But there's a few Moroni powered mopeds, and a bunch of Moroni powered mopeds, scooters, and trail bikes.
And they rebranded both engines as cimatti, too, with minor changes, mostly to the covers.
Well,Morini and Minarelli are two of the best engine brands out there.
