Derbi build
I got a derbi Variant from a friend on the cheaps. Frame wheels and a box of motor shit. I've build a couple ratty peds but this is my first ground up paint and all build
Crank was pretty bad. Rear pulley cheeks we busted from when PO tried to use a three jaw puller to take them off
Gears were in surprisingly great shape
Re: Derbi build
* wormdirt * /
Everything cleaned up pretty good crank was OK after some time with a Dremel and wire brush
Frame was ratty enough for me to try and paint it
Re: Derbi build
* wormdirt * /
Primered
I think variants look really utilitarian so I went with an OD green and black color scheme. But I really I couldn't decide so I went with subdued colors
Mini ramp turned into a spray booth
I bought the forks off of here, they're from whatever variant has the bars that lock into the front forks, as opposed to a handlebar clamp
Re: Derbi build
* wormdirt * /
If I do this again, I'm going to either not bother with paint, or go full retard and spray it with a spray gun. Even really good rattlecanning just isn't a tough enough finish
I got the rear shocks off of here. The rubber bushings were fucked and they were missing the metal insert. I took the bushings off a Peugeot and had a friend machine the inserts for me. I really with I had a lathe myself
Re: Derbi build
A lathe is on my list of machines to get as soon as I have space. Looking forward to more of this
Re: Derbi build
Great work. Its cool to see these things get brought back to life.
Re: Derbi build
* wormdirt * /
I was fucking around with some vintage Yamaha forks I had laying around but I chickened out because of the weight.
Still looking for a set of KX forks or something
Re: Derbi build
The derbi could take the weight of those kx forks. Should be fine and added safety.
Re: Derbi build
* wormdirt * /
What I mean was the weight of the forks is too much. Those are off of a 70s Yamaha street bike
> added safety.
Re: Derbi build
Emil Kniemel /
I think those forks looks great. How heavy are they? Im a noob so why is that an issue to be worried about?
Re: Derbi build
A little extra weight up front might be a good thing .
Help keep it well planted . ;)
Re: Derbi build
* wormdirt * /
The forks are from a '79 Yamaha 550 or something. I have them from a bobber project my brother was gave up on. They have to weigh at least 40lbs without the wheel and surprisingly the head tube is too short for a Derbi. They might end up on a maxi ripper I'm in the middle of though.
Kinda phoned it in on the wheels. They look OK.
Just over painting so I can start tuning
Re: Derbi build
* wormdirt * /
At the urging of the treats guys I did the one way bearing mod. Went pretty smooth.
Hogged out (somewhat) and polished up the stock intake
Finished the back wheel and got excited and threw together what I had done
Re: Derbi build
* wormdirt * /
A less shitty shot
Pretty bummed about the forks they pretty fucking shoddy even after being rebuilt. I've been looking for some KX or YZ shit locally, no dice. Those GS550 forks are starting to look tempting
Re: Derbi build
My forks clack over every pothole gonna try and fill em up with grease to attempt to have a little more dampening
Re: Derbi build
I really like the way derbis look with not derbi forks.
well "like" is maybe generous, but i think they look better anyway
Re: Derbi build
* wormdirt * /
That thread with all the derbi fork swaps is nice. I'm sure I could Fandango something but I don't have a working welder right now and relying on other people to fab shit is awful.
Re: Derbi build
Probably Fred /
I hate seeing rusted to crap crankshaftson
it boils my blood,
so much that could be avoided if people just didn’t leave the top end off and then let it sit out in the elements Or spray some fogging oil in it whatever,
Re: Derbi build
* wormdirt * /
The story goes that a pair of derbis were bought by a dude new. Maybe 5 years ago his sons ghost rode them into a drainage ditch. There were totally filled with water. My homie bought the pair for a ludicrously low sum. And now I have one. It would be funny if it wasn't moped abuse
Re: Derbi build
Justabunchoftrash 646260 /
Do a blunt to fakie!
Re: Derbi build
todd amundson /
He can’t even ollie
Re: Derbi build
ROMARIC PIVAIN /
nice job
Re: Derbi build
* wormdirt * /
Whoo ran it today, first time on my frame setup.
No brakes yet because fuck that rear brake setup. I have an old cable but it doesn't match my levers? Oh well. Still waiting on axle tensioners from DOS, bless those derbi Bros
Set the timing to 1.8mm BTDC
Still trying to figure out a good place to put the ignition, if anyone has a suggestion that would be great. I hate where the stock ignition sits, not something you can really tighten down
Re: Derbi build
* wormdirt * /
Oh and I can't Ollie, I picked skateboarding up again a couple years ago to pass the time on tours and I stick to transition riding, like an old fucking man.
Re: Derbi build
* wormdirt * /
I have a stock cylinder with the infamous "no window" piston
Going to cut the window on the all the way to the skirt, and try my hand at chopping up the piston when I get the balls
Re: Derbi build
* wormdirt * /
Came out pretty good I think
I don't know how far to take this, doing more research
Shined up the mating surface
Started polishing up the exhaust port
Re: Derbi build
* wormdirt * /
Piston is chopped
Going to do an A/B tomorrow with a stock non ported cylinder and the ported
Re: Derbi build
* wormdirt * /
Scrambler vibes I think
Still on the stock jug, 15mm Bing, Puch pipe hack n weld, 21 grams variator weight and this thing rips.
Definitely need to add a little more weight when I put the ported jug on
Re: Derbi build
* wormdirt * /
Re: Derbi build
Looks real nice sir!
