Re: I'm Glad I Took This QT Engine Apart
live ɘvil /
> Bob Naske Wrote:
> The bulb bench tested OK but I found the oil pump shaft seal had popped
> out of it's place and the lip spring had broken, possibly allowing
> some/all of the oil to drain into the transmission. The
> water/transmission oil cocktail had some tinges of purple coating the
> gears so that could have been 2T from the oil tank, draining it and
> causing the scoring/seizing rings. Speculation, I know, but there's
> always something new to learn no matter how long we've been fixing
> stuff. I'll test the oil level sender when the engine is re-installed
> and there's electrical power to test it. Thanks for the suggestion.
I always try to figure out the cause of a problem, starting with the simplest things first.
